Old 9th January 2013, 02:41 PM
Consider others, Supersprint are supposed to be even better in terms of quality. People just generally seem to go Milltek as it is tried and tested. Milltek's are about £1k though, or nearly £2k for a full system like the one I have, you could put a straight pipe through the back boxes like Neil and see if that gives you the V8 noise you crave, you can do that for a couple hundred quid. You will see more benefit from a short shift vs remap on this engine. Have you weighed up if it’s worth going for LPG?
