If anyone's interested. Just recently did this and that video wasn't much help at all. There's a youtube video tho in Russian, which shows... exactly how it's done. Slow it down, watch it a few times and, worked for me. One thing about that seal and cap, I found it's much easier if you lube up the large ring and cap threads with silicone lube, will allow smooth seating of the ring and tightening of the cap. Really don't need the special took for the cap, just tap it down with small hammer and maybe hard piece of wood so as not to damage the tabs? Needs to be quite snug or you'll get leaks and be smelling fuel. Mine wasn't tight enough, had to take it back out and lube up the parts, went smooth after that.
