I have replaced a compressor after I bought the car as the Original one was faulty. I replaced the AC condenser and dryer as well, so those components are new. Now for the problem. The AC is not cooling the car! If i turn on/off the ECON it does not make any difference. I thought it was the water valve with the pump and I replaced it as well, but makes no difference. If I set it to warm, it does blow hot air, but in LOW setting, like it was without AC. The system is 100% leak free as we tested it couple of days ago. What could it be?
I have few codes in HVAC module but none for the Hot/Cold air flap, but I do have the code:
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
If I do the basic setting test, it does not finish, it throws an error.
Guys what else can I do??
