Headlamp bulb holder
I have just bought a motor from China for the inside of the headlamp, not yet sure if this is going to cure the fault but its got rust on the wiring connector, the active bending light flashes on the dash.
I first thought that when turning the light turned the direction your going, but it only comes on In that direction silly me.
My other problem is the same as others in the light is yellow in colour even the side light compared to the other side, its a new headlamp fitted when I bought the car.
Have I read that the xenon bulb holder can be replaced by EM lighting.
Does the person that owns this company come on here, or do I ring them direct.
Also can I fit this part when I replace the motor or does the headlamp have to be pulled apart.
Hopefully someone will have all the answers,
I have one and its torch it.
Is a D4 more reliable?
Tps quote £650 for headlamp, more than the cars worth
David
