Originally Posted by Conquistador
Only problem I encountered was when I offered the refurbished wheel up to the hub to fit the bolts. Because there is now an extra few layers of paint, it was a very tight fit slotting it onto the centre of the hub. Had to take a razor blade to the inside of the hole and scrape some paint off and very slightly increase the bore so it was a comfortable fit. Perhaps they should have masked the centre hole as well as the bolt holes when spraying?
And the above post clearly isn't the last I'll have of this problem...
Tried to remove the wheels yesterday to put the 18" S8 wheels back on for a few months as they have new winter tyres, and these 20"s are practically welded on!
Any tips on how to remove them? Trolley jacked the car up then tried gradually winding the jack of death against the wheel to pop it off, but nothing.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
