Hi There,
S8, d2, with 345mm Bembro calipers as standard. Just changed for EBC Red Stuff and slotted ultimax discs on the fronts. (a quiet combination, drilled or yellow will add noise).
They seem to be good and quiet so far. But have only done 280miles and most was crusing a motorway (240). The car seems sweeter to drive. Less judder. But then the old pads were down to metal and the discs scored (i knew i was changing both)
Need to swap the rears for EBC standard discs and red stuff pads yet but wanted to run the fronts in first.
cya,
Lee
Reason: Moved to Front Brakes
