Your is a late FL (like mine) model so will have lambda sensors before and after the cats - there are two, one on each bank. One is built in to the pipework on the cat itself on one side (the other side is in 2 parts IIRC).
I replaced one of my cats a while back at "significant" cost. The old cat (which had to go back as it's all done on an exchange basis) apparently had effectively nothing inside it.
I bought the car knowing it had a bad/rattly cat on one side and it got worse and noisier until most of it had been spat out of the rear.
No warnings and it still passed the MOT for 2 years! But that's no guarantee yours will be the same.
I had to have one new lambda sensor as well as it just couldn't be removed from the pipe and the wiring had to be cut. Wasn't faulty though and they did get it out eventually with major brute force. Probably ended up on eBay....
