Originally Posted by mannyo
plus 2 other physical servers which are required due to needing access to PCIe cards.
I had the same problem, but run PCI passthrough. Works faultlessly on ESX 5.0.0, but is widely documented (and proven by me) to be totally shafted in any later version. Doh.
The days of servers having storage are limited (well, over in most cases)
Separating compute and storage makes sense full stop. When storage is all in one place its a lot easier manage. When compute breaks, throw it away and get a new one. You've lost no data.
I run a Synology NAS at home, and feature wise its dripping with them, performance wise the 1GB lan is the bottleneck every time. Power, it uses very little. It also has a lot of apps available, including CCTV. All compute is on ESXi as its just easier (and cheaper) that virtualising over windows.
In terms of raid, even at home, losing access to data whilst you restore from backups is a pita. For that reason alone, I would run at least Raid 1 to give you a chance of keeping things going whilst you replace the failed disc.
Also, mirroring from a 4TB disc to 2 spanned 2TB discs, if even possible on a desktop O/S is a bit messy. Mirroring is best performed across identical geometries, however any mirroring beats none at all.
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
