Originally Posted by steamship
The 'lift' option greys out once you go above 50mph, so can't figure out why it's greying out all the options above 20mph, unless it's picking up some issue that's going into a failsafe mode, but isn't leaving an error code. Do they enable again once you go below 20mph, or do you need to switch it off/on? With no error codes on it, would it be possible to drive it above 20mph and then scan it whilst in motion to see if there's a code? I think this is called 'grasping at straws'.
Regarding the compressor, I was going by one of your previous comments about testing it, unless it was just a typo.
I'm sure you can adjust the speed at which it greys out somewhere in vagcom settings / menus but cant remember if its in the standard areas or the green menu settings, so its also possible that someone has altered it and it could just be set back to say 40/45
