Old 29th May 2019, 11:11 AM
Its a common fault, and as such has been mentioned many times and documented here in a few different threads.
Its not recommended to push a welding rod down the tubes as that can puncture them and leak cause leaks into the car.
Usually though they do block requiring regular maintenance.
I personally use a bug spray bottle modified to squirt the crap out of the tubes.
Scuttle area also needs constant attention if you live anywhere near trees.
