Originally Posted by smoothcoupe
Hello guys, I have recently tried to fit an RNS-E to replace existing RNS-D to the 2000 S8, all the adapters were there, tried to source CAN from both old TMC plug as well as the pins in the instrument cluster but the satnav is not receiving the correct signal and does not work correctly. With CAN wires connected, satnav will not let me in passed the pin code screen, pin code is correct, after I disconnect the CAN pin code works but then there is a typical CAN misinformation as not remembering the pin code, no illumination with lights on etc.
Also, not sure if related but maybe, I got these 2 error codes in the instrument cluster :
01336 Data Bus for Comfort System 80-00 - Single Wire Operation
01311 Data-Bus information No communication
Any valuable suggestions on how to get this working would be highly appreciated.
Thanks and happy new year to all the A8 forum users!
If its 2000 year then it might be an RNS-C rather than D like my D2 1999 is in which case you will need an adapter cable from Kufactec from memory
