Old 1st September 2017, 10:04 AM
North2007 North2007 is offline
Default Fault ABS Sensor Rear Left
Guys, this fault came up recently. Results in the ESP/ ABS warning lights and deactivated park brake. After changing the sensor, fault still there. Used VCDS to establish fault came up before wheels turned. Turned out a bad connection at the terminal ABS pump up front. Cleaned up the male pins, reconnected and fault gone.
2003, A8 D3 4.0 TDI
