Originally Posted by The_Laird
I knew that you’d know, MJ. I’m sure that mine is Ebony Black Pearl - I’ll check the build sticker, but I share your thoughts on new panels, Michaela. Will the glass need swapping out, or do the panels come complete from Prestige?
The door would come as a bare panel so you would swap your window frame assembly, glass, wiring harness, lock etc over to the replacement.
The bumper and arch liners need to come off to get the wing off. I'd say its comfortably a day's work to get it all changed over sympathetically and line all the panels up.
