Driver Side Heated Mirror not working
Hey guys need your input on this please.
So for over a year now, my driver side heated wing mirror hasn't been working. VCDS reveals the following error message:
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 F
Component: Türsteuer.FS BRM005 0180
Coding: 0028462
Shop #: WSC 02313 785 00200
VCID: 20486A13F3B91341C9-8074
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 0
Reset counter: 233
Mileage: 138176 km
Time Indication: 0
Date: 2017.06.28
Time: 23:35:28
I have run several diagnostics and it has costed me quite a bit.
I was able to source a replacement mirror on ebay same as the original but that didn't fix the issue.
Next I checked the wiring between the mirror and the door control module ecu, and that seems fine as there is continuity running thru the wires after checking with a multimeter.
And lastly, I replaced the door control module with a replacement but unfortunately that still didn't fix the issue.
Can anyone shed some light on this please.
The Passenger side heated mirror works fine.
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
