Originally Posted by Prefferle
Thanks Homer, I’ll do that next... putting the harness back together along with replacing brake switch again first👍
Update - taped up and fitted the wiring harness along with all bits. Fitted an Audi OEM brake light switch, reset all Codes then test drove with 80+ brake pedal presses with NO FAULTS😁👍
It’s was difficult to believe that the aftermarket Febi part was an issue as Febi is a reputable brand but....😕
Another lesson learned.... Audi OEM all the way (Mabey not for suspension parts as I use Meyle-HD for years in all my past cars).
THANKS FOLKS for all your support👍
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
