MCS - great thank you so much for the tips
I've had starting issues which leads me to believe it's not the main pump that is a fault.
Once the car eventually starts it then tends to run fine.
I have the documents regarding removal and fitting and I've been reading it through.
I'll attempt this with a friend who is more competent with spanners than I am but I can certainly help.
Thanks again.
