I'm sorry to hear that. I had a battle to get mine fixed after the front bumper was damaged. As mentioned earlier, be prepared for a write-off and a low value. Whatever they value your car, you should be able to get something similar to what you have for the value (not at all easy) so having doing some research always helps.
I emailed
https://www.motorclaimguru.co.uk when trying to sort mine out, he seems quite knowledgeable and may be able to help if you are having problems with the value or repair.
Wishing you all the luck you need.
Cars...
'00 Audi S8 Agate Grey (Sold
