Originally Posted by JulianHicks
Thanks Guys, once again, for all your useful and helpful advice.
I happened to be in Lidl yesterday and picked up the oil pump thay had on sale, so I'm going to 'give it a go' with that.
Just one last query I forgot to add earlier:
What VCDS SRI options do you perform? [Set and oil change as 'longlife'; set as 'longlife' but oil change and SRI after 12 months/10000 miles; set and oil change as 'fixed' 12 months/10000 miles]?
[I see that these 'unbranded' oils claim to be for 'Longlife' service and have low SAPS contents for DPF equipped Diesels [like mine]].
Regards - Julian
The only slight problem is you need an extension from the D3's battery in the boot or use a separate battery to power the oil pump (like I do).
I didn't alter any service reminders with VCDS.
Matt
