I am guessing a coding issue of the instrument cluster, when I had my D2 and swapped the radio to an RNS-D I had to code the cluster as the RNS-D was using a different protocol to talk to the cluster.
Maybe MJ could post the coding of the S8 cluster with S Mode and you can compare with yours, but it maybe an adaptation channel that needs altering.
