Originally Posted by ainarssems
L3+ is definitely best for now. But if you look at network hashrate for the most popular coin - Litecoin the total hashrate is equivalent to about 57k L3+ so when a lot more L3+ come online or if somebody else releases more efficient machine profitability could drop a lot. By comparison Bitcoin network hashrate is equivalent to almost 800k S9's so if somebody ships 10k units of twice as efficient miner it will hardly make a dent so S9 while less profitable seem like a safer bet. Obviously it also depends on con price and other factors. At the current price at $1265 S9 seems reasonable.
Very good point. And that's probably one reason why the S9 hasn't been superseded in a relatively long time. I suppose the S7, and earlier models, are more like the L3+ in that respect, in that they came out at a time when the market saturation was much lower, making their profitability periods shorter. Thinking about it that way, I suppose buying more S9s could be the better investment. Ideally we need an S10, or whatever eventually superspeed the S9 -- something with a similar efficiency and profitability to the L3+ but that will likely remain profitable for longer.
MiningRigRentals sounds intriguing. I'd be interested to know what results you get if you do try it.
