AC compressor clutch?
Hi guys. I have been getting myself ready for taking the engine out to repair whatever damage has been caused by the broken timing chain. Obviously I need to discharge the AC system and disconnect several of the pipes.
The manual states that the system needs to be re-charged before starting the engine for the first time. I have read somewhere that there is no clutch on the AC pump and if it is run without gas then it will destroy the pump.
Is this the case? Obviously i don't have the equipment to re-charge the AC here at home so it would be a lot easier to put the engine back in and get the car running again then take it to get professionally done.
If it is the case that I really do need to re-charge it first, i will look into hiring the vacuum pump etc and do it here. It would be devastating to do that extra (expensive) step only to find the engine still doesnt run and needs to come back out again! (that would be devastating anyway!)
Gill
Daily drive: 2008 A8 4.2TDi
2003 A8 4.0TDi. 4 zone climate, double glazing, Bose - dead
Other cars: 1980 Land Rover Series 3, 2.25d, hydraulic winch,Van/station wagon/topless depending on my mood
1990 Land Rover 90 factory county station wagon with all the luxury additions, such as a clock and a tape player.
2007 A4 3.0TDi s-line cabriolet quattro
2000 A8 D2 2.8 quattro, looking for a new home - gone
2003 A6 3.0 quattro, in the way... anyone want any parts? - gone
