A long M10 spline / triple square. I think thats really it.
Soak the exhaust manifold nuts in something for a while. Chances are the two long ones which go through the manifold will take the studs out with them since you can only get penetrant to them with the engine out and on its side.
Bolt order is the same as you'd expect for a 4 cylinder.
Engine in or out?
