Old 22nd June 2016, 08:19 AM
Storka's Avatar
Storka Storka is offline
That's probably just a marketing, as far as I know most of the struts (if not all) will be filled with nitrogen as are gas filled shock absorbers because nitrogen molecules are fairly large so they escape less and nitrogen does not contain oxygen like air would so does not oxidise oil in the struts, on top of that it is cheap and abundant.
Yes the strut man when he did mine put them in a steel tube and pressurized it with nitrogen. I saw the nitrogen bottle connected to it.
It was a homemade setup. Steel tube with screw on cap.
Put struts in the tube pressurize and gas is forced past the o rings.
It is harder to reduce the pressure in the strut apparently
