Recoding from 00101 to 00111
After reading this thread I thought that i would see if this made a difference so in an idle moment, I have just re-coded the transmission from 00101 to 00111. Just had a quick once aqround the block to check all was OK (it was) before stting off in an hour to pick up son from airport. I have already noticed that it changes down earlier when the throttle is depressed so look forward to the 30min drive to the airport. Unfortunately, the speed limiter will be with me.
