Thanks Paul, sounds like the USB option is not a good one then - I had assumed you had drilled a hole and put a grommet the same as the link in the Blackvue post.
Can you recall how to remove the overhead console so that I can have a poke in there with a meter to see if there is a switched feed anywhere - maybe the sunroof?
