quality feedback thanks a lot, I will attempt vcds again and report back.
I did attempt to code the battery but couldn't see the 10 digit serial number on my new battery - there is a number under a barcode but that is 13 digits.
Although there are no ignition lights when I put the key in and turn it once, the radio will come on and it is definitely recognising that the ignition has been turned on (if that makes sense). All Electrics work fine, the remote control locking is fine, seats blinds lights, nav, everything working as normal - its just the ignition lights and obviously the engine not making a sound when turning the key to start.
thanks for the replies - let the investigations begin!
