Old 3rd March 2019, 01:19 PM
Yes,
Its all pretty simple.
In your case you need 3 relay outputs, 1 for the pump, 1 for ho****er, and 1 for heating. Your two inputs are time and the output status of the themostat.
The pump should run when only 1 of the other 2 are active.
I multizoned my house some years back, and run everything off digital temperature sensors (fed into a PC via RS232) and basic logic operates a bunch of output relays (also controlled by RS232). Its old school, but very reliable and easy to debug.
Thats an extreme solution for a single zone house, but all you need is some basic timing and themostat live or not logic by the sounds of it....
