At least if it comes back again you've confirmed it as a likely cause if it stops it for a few weeks.
I had similar with a front ABS sensor that I was convinced couldn't be faulty, as it's the only one I've previously had cause to change! Sure enough after 5 years and some copious fiddling I had to accept it was getting worse. New sensor and been perfect since!
