Rear blind cover appears loose
My S8 is on SORN and hasn't moved in ages, but today I was just checking the battery (still OK) and noticed through the back window....
It looked like an unwanted gap at the rear edge of the blind cover; same both sides but larger in the centre near the rear light.
Going inside the car I could push the rear edge down easily, but it sprang back up.
Presumably this is supposed to be "down" not as in the photo?
How is it secured, and is it easy to remove and refix correctly? As ever I guess there's a trick to this as there are no obvious fixings.
