Old 28th May 2019, 09:26 AM
The antenna is attached from inside the rear quarter. You'll need to remove the boot side trim to get to it, and iirc there's one bolt holding it to a bracket. It then drops down out of the rubber grommet - the force it needs can be quite scary as they're all pretty crusty by now. If it's stuck, tt helps to drop some lubricant (WD-40 etc) down between the aerial base and the gromment from outside, and then wiggle it around a bit to free it. The grommet is then just a push-fit in the panel.
There are a couple of versions of the aerial base depending on which options the car has (phone prep etc), and it has different connectors accordingly.
