Old 25th January 2020, 06:20 PM
My A8 has H7 foglights but the bulbs plug into a captive connector inside the light with a wire going to the inside of the back cover. There is an external socket that just looks like a standard VAG 2 pin flat contact. What is yours like? If incorrect, maybe you can just crush the incorrect plastic housing into bits and click the pins into a new (correct) housing?
Also check aliexpress and ebay, you can get cheaper pattern parts for these lights and grilles. You also need those green plastic plugs to put in the holes in the bumper for the screws to screw into.
