Old 9th June 2018, 01:53 PM
Regulus Regulus is offline
Default Window regulator failure
I am in the process of trying to repair the left rear window. First I looked at the switch, as I hoped I might not have to pull the panel off.
Taking the panel off, I immediately noticed a piece at the bottom of the door.
After further inspection, the window regulator mechanism is clearly broken.
Any chance I can get it back together to be able to fully close the window?
edit: (I just remembered it is vacuum driven) HPsauce is correct, my mistake.
ID:	19427   Click image for larger version
ID:	19428   Click image for larger version
ID:	19429   Click image for larger version
ID:	19430   Click image for larger version
ID:	19431   Click image for larger version
Name:	Window regulator rear left.png
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
