I used my local Audi Dealer to do the ATF change and they used the Audi branded ATF fluid. I'll check the part no.s from the invoice and update the thread when I have them to hand.
It would appear to be a common issue with the 8 speed ZF box on F10 BMW's if you have a look on some Beemer forums.
The ATF change made no obvious difference with my car but overall its still a fantastic autobox. I suspect the issue may be software related rather than an issue with the ATF.
Unless it gets worse, I'm not too concerned.
