A further intriguing little twist on the body lugs below the windscreen and the slots they slip into on the plastic trim.
The bodywork on my S8 has two metal lugs, about 10cm outboard of the washer jet locations, this is the offside one.
Both the trim on my car and the one I bought from our sponsors have the same part number 4D2 905 097. Yet the purchased one has THREE slots and it looks as if the fourth slot has been cut off, it has a manufacturing date of 12/94 and came with unheated washer jets in situ. The extra slots are equally inboard of the washer jets so I guess some cars may have had lugs there.
I felt along the bodywork and there was no indication that my car had ever had the inner pair of lugs, maybe it was a PF thing and they were later dispensed with as superfluous?
The slots are a plastic piece that is added on later, fitting over plastic projections and heat-welded in place, I think mine only ever had two..
