As I now have this problem on Sports seats I've started to have a look underneath.
If it is indeed the front (moveable) section that has its own small pad and that usually is the one that fails I thought I'd start there as it's more accessible.
Looking under the seat there is a thin cable sleeve connecting the front section to the rear, held on by a cable tie.
I can't think it's there for anything other than the detector; I'm sure there's no heater in that section.
As it's much more accessible than the main plug and wiring I'm going to start there, cutting the sleeve open first to see what's inside.
If there is a main and secondary pad I can only assume they're wired in series. Can anyone confirm that?
If that is the case it might even be possible to bypass the front pad with an intermediate resistance value so that the main pad operates the system normally.
Edit: Just opened the sleeve - one blue wire, one white wire.
I'll be cutting through that and measuring the resistance of the disconnected front pad shortly......
Might it even be worth shorting them together, simplest solution of all?
