Old 29th October 2016, 03:21 PM
Yes like said ,clear down all codes , has the subframe or steering rack been removed to do turbo , is there a electrical connector on the steering rack head ?
Is the steering wheel straight ahead when driving down a straight road
It may need steering wheel centralisation adaption
Go into abs or steering angle sensor ,under adaptations and run through centralisation procedure
When wheel straight ahead angle should show 0 degrees , turn wheel one way it should count up , turn it the other it will count up but in a minus value .
Your code for steering angle is like something is diss connected .
A few things to go at ...
