Old 15th January 2018, 03:51 PM
Well, I recieved the spare part yesterday and fitted it.
Exactly the same codes and behaviour, so looking at wiring loom or swapping calipers from one side to the other to see if the issue moves. I don't want to take the motors off as the casing split last time I did that on my old one.
You might want to do a continuity check on each of the pair of twisted wires from the Brake ECU to the Caliper to see if that throws up and issues - I ended up replacing each twisted pair with my car to all four corners as the casing on the wire was intermittently cracking and exposing wires which then touched and threw up faults at all sorts of times! My only difficulty with that is that I cant see that issue throwing up that particular fault but certainly continuity check the appropriate wires concerned
