Hello I have now bought the used transmission and also the transgo valve upgrade and also an upgraded A clutch basket. This first roller bearing you mentioned which bearing exactly is this? Do you have a PN or some source for it? I’m thinking I will just go ahead and buy one since when I start disassembling the gearbox I don’t want to get stuck having to wait for shipping incase something requires replacement.
You will need to swap the D2 mounts and hardware over. F125 is the same.
I would get the converter reconditioned for sure because it sucks when you swap the transmission and then have to take it out again to replace the converter. Don't ask how I know that!!
Clutch packs are fairly easy to get, mostly aftermarket now as I believe ZF have stopped selling parts for them. Exedy make some, and there are also some Polish kits. The main thing if you have it apart is to check the condition of the first roller bearing and first clutch basket snap-ring groove. If they are ok, new clutches and seals and it should be good to go.
I've heard good things about the Transgo pressure valve upgrade too but not personally fitted one yet. If the replacement transmission is working then now is the time to fit the Transgo valve as it should prevent any pressure issues later on.
D2 A8L 4.2 AQF 4.2 LZ9W Ebony Black Pearl Fully electric rear seats 20x9.5 OEM peelers D3 s8 front brakes s8 mirror housings 18x8 Avus 3 winter wheels PDC rear blinds Nav Electric steering wheel adjustment rs6 MFSW heated with shift buttons TPMS Leather pack 1 with retrofitted stitched leather lower dash panels folding auto dimming mirrors solar sunroof cold weather package CD changer 2x12 subwoofers double glazing all around memory seats passenger seat adjustment from rear seat Bose servotronic xenon plus headlights
C5 Allroad 4.2 BAS 4.2 LZ6G Irish Green Metallic Bose RNS-E Rear Blinds folding auto dimming mirrors Heated MFSW with shift buttons PDC Recaros heated seats all around CD changer Nav
B5 A4 STCC Edition AJL 1.8T Quattro Built engine GT28RS maxxecu Remote locking Trip computer Sport seats Eibach/Bilstein suspension Flexfuel
C5 A6 1.8T Quattro AWT 1.8T Reliable, unlike the others
Previous Audis B7 S4 Avant B5 A4 Avant 1.8T B8 A5 SB 3.0tdi C5 A6 1.8T C5 Allroad 2.5 TDI
