If it is a stuck piston in the ABS unit then maybe some percussive maintenance might free it up? Maybe use the wheel brace to get in between the pipework and give it a whack with something heavy. That might free it up, although it may well get stuck on the next press of the pedal.
Thats all I can think of other than getting it recovered unfortunately.
Where are you at the mo?
I think its sticking generally. Pedal will be solid, and then at one point it will loosen up and all good, next time I brake it's all solid again.
Currently in Stevenage, mechanic I trust is on London
