Old 2nd February 2018, 02:28 PM
Regulus Regulus is offline
Default vcds scan after service
My S8 was serviced by Lecab, Audi Karlstad the 31st last month.
I made it home, with the engine oil lamp on and the rpm needle was dead.
Today I ran a scan with vcds to try see what it would tell me.
The engine oil lamp and the rpm needle worked today, so I took it for a drive. About 400m from my home the car made a few engine brakes, or I think it did. Then it died. So now the car is on it's way back to Lecab with roadside assistance.
Here is my auto scan before the road failure.
VCDS Mobile 0.4411.0.4
Chassis Type:4D
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
Address 01: Engine Labels: None
Part No SW: 4D0 907 557 N
Component: 4.2L V8/4V MOTR AT D01
Coding: 04373
Shop #: WSC 02324 000
VCID: 3731B8DF19C18580022971845-4B1E
12 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
01183 - Warning Light for Catalyst Monitoring (K72)
31-00 - Open or Short to Ground
16705 - Engine Speed Sensor (G28)
P0321 - 35-10 - Implausible Signal - Intermittent
17917 - Idle Control Valve (N71)
P1509 - 35-10 - Electrical Malfunction - Intermittent
17817 - EVAP Purge Valve (N80)
P1409 - 35-10 - Electrical Malfunction - Intermittent
17609 - Fuel Injector for Cylinder 1 (N30)
P1201 - 35-10 - Electrical Malfunction - Intermittent
17613 - Fuel Injector for Cylinder 5 (N83)
P1205 - 35-10 - Electrical Malfunction - Intermittent
17612 - Fuel Injector for Cylinder 4 (N33)
P1204 - 35-10 - Electrical Malfunction - Intermittent
17616 - Fuel Injector for Cylinder 8 (N86)
P1208 - 35-10 - Electrical Malfunction - Intermittent
17919 - Intake Manifold Valve (N156)
P1511 - 35-10 - Electrical Malfunction - Intermittent
16944 - System Voltage
P0560 - 35-10 - Malfunction - Intermittent
17968 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
P1560 - 35-10 - -) - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No SW: 4D0 907 389
Component: ABS/FDR Allrad D3202
Shop #: WSC 00000 000
VCID: EC9BD7B390077658BF3B36004-51CE
1 Fault Found:
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
Address 08: Auto HVAC Labels: None
Part No SW: 4D0 820 043 K
Component: D2-KLIMAVOLLAUTOMAT D05
Coding: 00080
VCID: 240B7F93B857FE18B76B9EA0C-2568
4 Faults Found:
00715 - Rear Footwell Vent Positioning Motor (V112)
41-10 - Blocked or No Voltage - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
41-00 - Blocked or No Voltage
00734 - Potentiometer in Central Vent (G142)
30-10 - Open or Short to Plus - Intermittent
01592 - Air Quality Sensor (G238)
57-10 - Electric Circuit Failure - Intermittent
Address 15: Airbags Labels: 4D0-959-655-AI7.lbl
Part No SW: 4D0 959 655 H
Component: Airbag 7 Audi 050C
Coding: 00225
VCID: 3731B8DF19C18580022971845-5118
No fault codes found.
Address 17: Instruments Labels: 4D0-919-033-MYW.lbl
Part No SW: 4D0 919 033 AF
Component: D2-KOMBIINSTRUMENT D53
Coding: 00683
Shop #: WSC 19411 000
VCID: 68932BA304FFDA785B136AF00-508A
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No SW: 8L0 862 257 N
Component: CV-Pump D06
Coding: 13130
VCID: 40C3D3034C0FC238B383D2108-4EEA
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No SW: 8L0 951 173
Component: Innenraumueberw. D04
Coding: 00001
VCID: EE9FDDBBA61B8448914F2C382-4AA4
1 Fault Found:
01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
27-10 - Implausible Signal - Intermittent
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No SW: 4B0 907 357
Component: LEUCHTWEITEREGLER D001
Coding: 00008
VCID: E58DA29773ED4710E0F5CBACF-5160
1 Fault Found:
00776 - Level Control System Sensor; Left Front (G78)
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No SW: 4B0 035 186 E
Component: Radio 0001
Coding: 00207
Shop #: WSC 02325 000
VCID: 2207798BA243F028C55768886-4B00
1 Fault Found:
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
Address 76: Park Assist Labels: 4B0-919-283.lbl
Part No SW: 4B0 919 283
Component: arkingsystem A8 RDW D17
Coding: 01108
VCID: E68FA59B8EEB4C08E9FFF4D8A-5216
2 Faults Found:
01543 - Parking Aid Warning Chime (H15)
01549 - Supply Voltage for Parking-Aid Sensor
29-00 - Short to Ground
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No SW: 4D0 927 156 BL
Component: AG5 01L 4.2l4V S8RdW D03
Coding: 00101
VCID: 74AB4FD348372E98E78BEE60C-51A8
1 Fault Found:
17087 - Brake Switch (F)
P0703 - 35-00 - Electrical Malfunction
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
