Originally Posted by MattyV8
Finally replaced my key fob case - total cost for new case with gaskets, battery and screws plus little audi badge on front - £9 delivered. The key doesn't feel cheap as I thought and actually looks oem.
Really easy to do, take the badge off, unscrew the screw then pull apart. There are 2 little screws at the bottom which need to be removed to get access to the circuit board. Put the new battery in and put back together.
I used my old key with the new spring and button so still looks new.
Pressed unlock and worked perfectly. Car sensed keyless features too. I put it in the ignition and turned on and off just to be sure.
A step by step photo would’ve been good for us numpty but well done
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
