Thread: Headlamp issue?
Old 27th August 2014, 10:26 PM
He clearly took out the most expensive and desirable lights on D3 and downgraded you to just Bi-Xenon with halogen DRL, no cornering lights and no LED DRL. Thats why your original coding was wrong for the current headlights, but correct for the one which were installed.
Good thing is that if you decide to upgrade your headlights to original ones, then it will be just a straight swap as you are wired already.
Not sure is having car wired for stuff you don't have anymore can cause problems, but I wouldn't though so.
I'm sure others will give more info about wiring situation atm.
PS. I have posted your disk just today via 1st class as I was very busy yesterday, sorry Mark.
