Old 1st December 2018, 08:28 AM
My car has often been like this after using VCDS. I used to run a scan for 5-10 mins, shut down, lock up and in the morning a flat battery and battery - 10% on display. It seems better if you make sure you close controllers and unplug the interface from the ODBII port before you turn off the ignition.
