Not sure I understand this 18mm socket/spanner lark My ancient draper socket set had an 18mm and the Kamasa (W Germany) combination ring/open ended set has an 18mm and I have two ring spanners (Heyco - W German) and Draper which also have 18/19mm ended ones??
If you would have asked I would have lent you a pair IIRC my drop links were 18mm bolt with a 17mm nut - or vice versa.
