Originally Posted by limoncello
got one in halfords the 019 model though rather than the 20, still a bosch s5 it looked fairly tight
Funnily enough I've been looking to get a new battery for my D2 (PF S8) as although it's fine it is also quite old (nearly 10 years - I fitted it myself!) and I suspect it could fail any time.
(Luckily with the PF D2 all you do is swap them over, nothing else to do except re-enter the radio code. )
However I do have a PDF document downloaded from Bosch that details what batteries go with what car - I'll attach it here. As far as I can see the D3 has basically the same size battery as my D2 S8, and the Halfords 019 is correct; 020 would be too long. The standard size seems to be 353 long, 175 wide and 190 tall (mm).
I currently have a Bosch Silver 8A (part 0093 S5 880) and the recommendation now is for an S6 002 (same as for D3) or S5 013 (0092 S5 0130) so I'll presumably go for the S5 013 which happens to have not only slightly higher capacity and CCA than my current battery, but actually more than the S6 as well!
Hope the document is useful, it's a few years old but covers a wide range of car makers.
