Friday,28,October,2016,10:54:13:12992
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ4E54N002615 License Plate: A8
Mileage: 235700km-146457mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 72 76
VIN: Mileage: 235700km-146457miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 409 C HW: 4E0 907 409 B
Component: 4.0L 4V/TDI G000AGMŖ0010
Revision: <> Serial number: AUX3Z0C3114402
Coding: 0010773
Shop #: WSC 02313 785 00200
VCID: 234593F0E2E7385A81-8076
3 Faults Found:
17983 - Right Engine Mount Solenoid Valve (N145)
P1575 - 000 - Short to Plus
Freeze Frame:
RPM: 0 /min
Torque: 27.3 Nm
Speed: 0.0 km/h
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Temperature: 10.8°C
19591 - Intake Manifold Runner Control
P3135 - 000 - Lower Stop not Reached
Freeze Frame:
RPM: 0 /min
Torque: 27.3 Nm
Speed: 0.0 km/h
Duty Cycle: 87.9 %
Duty Cycle: 20.7 %
Duty Cycle: 0.4 %
Temperature: 10.8°C
16497 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High
Freeze Frame:
RPM: 0 /min
Torque: 27.3 Nm
Speed: 0.0 km/h
Voltage: 11.70 V
Absolute Pres.: 999.6 mbar
Temperature: 9.9°C
Temperature: 10.8°C
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 J HW: 09E 927 156 A
Component: AG6 09E 4,0LTDI RdW 0010
Coding: 0000001
VCID: 295981D880CBE20ACB-807C
4 Faults Found:
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 20.0°C
T.B. Angle: 0.0°
Voltage: 12.72 V
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 20.0°C
T.B. Angle: 0.0°
Voltage: 12.72 V
18262 - Powertrain Data Bus
P1854 - 000 - Hardware Malfunction - Intermittent
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 20.0°C
T.B. Angle: 0.0°
Voltage: 12.72 V
18289 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request - Intermittent
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 20.0°C
T.B. Angle: 0.0°
Voltage: 12.72 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 214999F8F8FB2A4A93-8074
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H02 0120
Revision: 01203602 Serial number: AUX3Z0C3114402
Coding: 0264192
Shop #: WSC 23123 823 56694
VCID: 58BFF41CEB21AB82A4-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00000 785 00200
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 G HW: 4E0 035 729
Component: Interfacebox H43 0770
Revision: 00000000 Serial number: 343EE037514412
Coding: 0000002
Shop #: WSC 00720 210 02493
VCID: 2C5778CC8F39F72230-8078
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 322AF037502693
Subsystem 3 - Serial number: ˙˙17.01.03˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙
Subsystem 4 - Serial number: ˙˙˙˙˙˙˙
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 015 0240
Revision: 00000017 Serial number: 00000000016781
Coding: 0022531
VCID: 5ABBEE14952DB99292-800E
9 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 53
Reset counter: 144
Mileage: 235151 km
Time Indication: 0
Date: 2016.10.14
Time: 20:14:25
Freeze Frame:
Voltage: 11.60 V
Temperature: 14.0°C
(no units): 201.0
(no units): 86.0
Temperature: -80.0°C
01858 - Air Outlet Sensor; Right Center (G348)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 64
Reset counter: 183
Mileage: 235153 km
Time Indication: 0
Date: 2016.10.15
Time: 10:41:35
00711 - Left Footwell Flap Positioning Motor (V108)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 29
Reset counter: 183
Mileage: 235153 km
Time Indication: 0
Date: 2016.10.15
Time: 10:41:42
Freeze Frame:
Voltage: 13.70 V
Temperature: 15.0°C
(no units): 62.0
(no units): 89.0
Temperature: -89.0°C
00819 - High Pressure Sensor (G65)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.28
Time: 01:55:33
00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 47
Reset counter: 183
Mileage: 235214 km
Time Indication: 0
Date: 2016.10.16
Time: 10:54:02
Freeze Frame:
Voltage: 13.90 V
(no units): 210.0
(no units): 255.0
00732 - Potentiometer in Positioning Motor for Right-Hand Footwell Flap (G140)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 182
Mileage: 235283 km
Time Indication: 0
Date: 2016.10.19
Time: 18:53:15
Freeze Frame:
Voltage: 14.00 V
(no units): 116.0
(no units): 255.0
00600 - Potentiometer On Positioning Motor for Temperature Flap (G92)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 178
Mileage: 235284 km
Time Indication: 0
Date: 2016.10.19
Time: 18:54:09
Freeze Frame:
Voltage: 14.10 V
(no units): 102.0
(no units): 255.0
01857 - Air Outlet Sensor; Middle Left (G347)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 183
Mileage: 235689 km
Time Indication: 0
Date: 2016.10.21
Time: 21:26:03
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 183
Mileage: 235689 km
Time Indication: 0
Date: 2016.10.21
Time: 21:26:03
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0010001
Shop #: WSC 02311 785 00200
VCID: 2A5B7ED485CDE912C2-807E
Subsystem 1 - Part No: 4E2 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
Address 11: Engine II Labels: Redir Fail!
Component: 4.0L 4V/TDI G000AGSŖ0010
Coding: 0010773
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H08 0940
Coding: 0431707
VCID: 63C5D3F0A267785AC1-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H09 0030
Coding: 0112141
VCID: 65C1CDE8AC53066A2F-8030
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 A
Component: KOMBIINSTR. VDO H42 0060
Revision: D07 Serial number: AUDID3C3000061
Coding: 0000403
Shop #: WSC 50741 143 61874
VCID: 5CB7E80C9F1947A280-8008
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
Freeze Frame:
Fault Status: 00000011
Fault Priority: 7
Fault Frequency: 4
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2016.10.22
Time: 18:49:45
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 HW: 4E0 815 069 C
Component: Heizgeraet H06 0280
Revision: 0000000E Serial number: 00000009001484
Shop #: WSC 00000 000 00000
VCID: 59B9F118902BB28A9B-800C
1 Fault Found:
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 160030480513E9
Coding: FCFEFBDE2B2104
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H43 0340
Revision: 00000000 Serial number: AUZ5ZBD4013149
VCID: 1939B118D0AB728A5B-804C
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0264192
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 F HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 6260
Coding: 0000001
Shop #: WSC 12345 210 01865
VCID: 26438AE491D5CD72E6-8072
1 Fault Found:
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:30:16
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory FS H02 0010
Coding: 4063330
VCID: 244790ECE7E93F62F8-8070
2 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 64376 km
Time Indication: 0
Date: 2006.07.27
Time: 13:15:35
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 144
Mileage: 0 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:00
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
Revision: 00000000 Serial number: 353J/047581796
VCID: 3B754B907A57609AA9-806E
2 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:10:37
02927 - DVD Read Error
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:10:28
Freeze Frame:
Hex Value: 0x3E5D
Hex Value: 0x5774
Hex Value: 0x0901
Hex Value: 0x0409
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0090
Serial number: 00000411100066
Coding: 0035840
VCID: 1D31A508C4830EAAB7-8048
2 Faults Found:
02139 - Control Circuit for Left Front Interior Lights
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:10:00
02138 - Control Circuit for Front Right Interior Lights
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:10:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.FS BRM004 0080
Coding: 0028450
VCID: 5EB3E204890555B2EE-800A
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040305140015
Coding: 0000217
VCID: 275D87E096DFD47ADD-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
2 Faults Found:
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 144
Mileage: 224720 km
Time Indication: 0
Date: 2015.06.22
Time: 17:15:05
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Reset counter: 144
Mileage: 184703 km
Time Indication: 0
Date: 2012.04.02
Time: 15:52:17
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 G HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0360
Revision: PROD_01 Serial number: 00000000047667
Coding: 0000011
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0060
Revision: Serial number: 00000000014231
Coding: 0010101
VCID: 5DB1E50884034EAAF7-8008
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.BF BRM004 0080
Coding: 0028450
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000431
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Time Indication: 0
Freeze Frame:
Voltage: 11.80 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Revision: 00000001 Serial number:
Coding: 0000002
VCID: 62CBD6F4BD7D7152CA-8036
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 C HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304EO037524595
Coding: 0000001
VCID: 204F9CFCF3F123429C-8074
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000000007380
VCID: 1F4D9F00CE8F1CBAA5-804A
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1403240272
Coding: 303030393135313035414B56413031343033323430323732
3 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 235151 km
Time Indication: 0
Date: 2016.10.14
Time: 20:18:07
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.28
Time: 02:10:50
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.28
Time: 02:11:00
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0080
Coding: 0028450
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0080
Coding: 0028450
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001008
VCID: 60CFDCFCB3716342DC-8034
2 Faults Found:
02069 - Front Parking Aid Sensors
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 184
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:46:22
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 14
Reset counter: 184
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.28
Time: 02:14:37
End-------------------------(Elapsed Time: 03:40)--------------------------
