Originally Posted by M-A8
On the right hand side it sits on the pillar trim and it goes behind the bonnet lever and left hand side torx screw as you said. I've done this panel many many times and never had an issue with it and its very secure.
Hard to tell.
Try refitting it and if you fail just dremel out a bit of plastic which you shouldn't be doing so keep trying and it will fit.
Is the black part above the pedals secure on yours? The panel under the steering wheel with the pocket all feels very secure, it's only the plastic part below that feels loose. I can push the flexible black part up ~5cm by hand easily, but then falls back down and rests on the brake pedal. I'm wondering if the black part should slot into something when fitted. I'll take it apart again and see if I'm missing anything.
Photo showing the "black part" here for reference:
http://www.ebay.co.uk/itm/132084235405
Thanks
