Thread: Blocked Drains
  #50
Old 19th May 2022, 03:30 PM
ulfilias ulfilias is offline
WHAT a lot of weather last night.....drive to work was on the drippy side!
I'd tried rodding the sunroof drains a little while back and i do it ocasionally, but it had gotten to THAT point!
Lift mode, Wheel turned and you can undo the back wheel arches with a torqs. 3 at the bottom, one at the top and flex them back.
Drivers has the fun of water bottle, some bolt/bolt screws and you can pull back and reach up.
Use of some strimmer plastic wire, hot soapy water and bingo. loads of crap. Find you can feed the strimmer wire up on the passenger side and floss your car
Current :
Previous :
Also :
