Originally Posted by Johnmed
I feel your pain. Been there done that. I think I was able to slacken off the calliper carrier and move it with one bolt removed. That way I got the disc off. My process was scuppered when the EPB module ate itself. By that point I replaced all the parts and handed the f**&er over to a garage to sort. They replaced the module and cleared some codes. I could have done that, but by that point I was a broken man.
The steel calliper carrier bolts on the O/S/F (alloy) hub were contact corroded to death. I had to use a blowtorch and WD40 on the bolt, with an impact gun to get the thing to turn. The N/S/F came apart easily as could be. I still shudder at the memory of that afternoon, that became a weekend of pain.
I love Audis but they really aren’t that nice to work on. I still remember trying to replace the battery on my A2. Thought it would take minutes. Over an hour later I was still cursing the thing as I stared at the old battery in situ!!!
I’ve worked on all my cars and family members’ over the years, without so much hassle as I’ve had with the A2 and A8.
Whereabouts are you OP?
I'm in Dublin, Ireland. I managed to get the discs off in the end like you said - with one bolt removed and the other loose the carrier could be moved enough to get the disc out. I ended up taking all the carrier bolts out and replacing them although I'm still not sure how anybody is supposed to get a torque wrench on the two lower bolts. I've had the calipers back off a few times now at this stage trying to figure out what's causing them to stick as they were working OK before I went at them! I have a seal kit coming so maybe bleeding the system and rebuilding the calipers might solve the problem, although at this stage I'm very tempted to offload the whole thing to a mechanic just to be shot of it.
