And, as is often the case, having bought some parts I never used them, ended up reusing what I had, which also saved on transplanting all the heated washer jets, piping and wiring.
I did remember, as advised earlier, to use copper grease on the wiper arm splines, though they came off fairly easily.
The final result is a tight fit all the way along the base of the windscreen, now including the central section shown here:
